  1. I got a 900 mo MPEG file and I want to make it 700 mo to fit on a CD without changing the format. How can I compress it? please email me at mquillever@hotmail.com with a quick answer. Thanks
  2. Reducing the bitrate is the only way you will be able to fit it onto one cd.
    If it's wet, drink it
    My DVD Collection
  3. what should I use then to do that?
    Melbourne, Australia
    Use a Mpeg encoder
  5. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Also, trim off any excess bits like the introduction and credits in order to reduce the amount of compression. Look in the Edit section for guides.
