  1. hi,
    this is a off topic question,
    i cleaned up my computer using the cleanup facility in XP and i came across a dvdrhelp file which i cannot remove from my computer, what is this file and how can i get rid of it,
    [/img]
  2. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    What directory is it in?
  3. C:\Documents and Settings\myusername\Local Settings\Temporary Internet Files\Content.IE5
    i was thinking, when i soemtimes log on to the dvdrhelp site i sometimes check the remember my username, could it be that?
  4. It is probably just a 'cookie' (small text file some websites put onto your computer to do such things as remember your username). Sometimes Windows has a problem getting rid of them so I would just fire up the old DOS command prompt and delete it through that.
  5. thnks 4 the reply, pacmania_2001
