Hi all,
been using vdub to cut bad frames from avi and came to find nandub due to the guides here. It funtions pretty much like Vdub but it will not save to wave or avi. The box pops up after I hit save then disappears. It creates an 800kb file and will not complete the job. Simply extracting to wav doesn't work either. it just will not extract or save anything. Plays the video fine though. Am I doing something wrong or some setting I need to adjust?
Using winxp with amd 2700xp processor. Virtual dub will extract and save fine but I sure would like to use nandub as I hear it helps with audio sync issues.
you can try avi2wav for extracting the wav http://www.divx-digest.com/software/avi2wav.html
i use nandub for my cutting also,but you might want to check out virtualdubmod http://www.afterdawn.com/software/video_software/video_tools/virtualdubmod.cfm
some will play and some wont.
By kushy66 in forum Newbie / General discussionsReplies: 9Last Post: 22nd Aug 2011, 22:32 -
nandub 1.0rc2 slow seeking
By worm9110 in forum EditingReplies: 1Last Post: 28th Jul 2011, 12:07 -
Encoder using Nandub
By PageDown in forum Video ConversionReplies: 5Last Post: 20th Nov 2010, 23:18 -
Edit Avi: VDub / VDubMod / Nandub
By Rinsin in forum EditingReplies: 11Last Post: 1st Mar 2010, 18:33 -
virtual dub wont load the full vob
By tvlreject in forum EditingReplies: 19Last Post: 28th Mar 2008, 21:13
