I was just curious if it's possible for an application like Tmpgenc to use the ATI AIW's hardware compression for mpeg and mpeg2. Let's assume that the author of the software had the itch to add that functionality to his program. Could it be done?
Or are the compression algorithms and other technical things that I don't understand not compatable?
Since you can capture using mpeg2 in real time (assuming you get ATI's software to work), I was thinking that encoding times could really be speeded up, if the cpu could communicate with the capture card and borrow it's hardware compression.
I would like to point out that only the AIW 9700 and above have partial mpeg hardware encoding. It is not something that every AIW has, just the AIW 9700 and newer, and it is only partial, taking perhaps 5% off cpu usage. I would also imagine that the ATI apps are written to take advantage of this specially. Any other program would have to be doctored to use the HW compression.
Originally Posted by Muffzilla
If you notice, ATI doesn't even promote the MPEG encoding. I've looked into this a few times, but I don't have the time anymore. I don't understand enough about computer chips to reverse engineer or analyze them. All I know is what I read in industry reports and what I experience first-hand.I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored.
Hardware MPEG-2 Capture Software ATI Theater 550 Pro
By CaZeek in forum Capturing and VCRReplies: 9Last Post: 22nd Nov 2010, 11:57 -
Capture Cards with hardware compression to Xvid/Divx?
By quantass in forum Capturing and VCRReplies: 7Last Post: 31st Aug 2008, 19:50 -
Dell/ATI Xcelerator, Hardware encoding, general questions
By Slip Jigs in forum Video ConversionReplies: 0Last Post: 20th Mar 2008, 17:26 -
Can you use third party capture software with the Intensity?
By gigantibyte in forum Capturing and VCRReplies: 0Last Post: 6th Dec 2007, 12:16 -
3rd Party Capturing Softwares...
By mediamaster in forum Capturing and VCRReplies: 1Last Post: 7th Oct 2007, 04:21
