Hi, I have tried and tried and read everything I could find but I can't solve
my problem. I have Encoded my film and when I try to burn it I get this message:
ERROR: No driver found for 'HL-DT-ST CD-RW GCE-8400B' (Use "Force Driver" in the "CD Writer/Reader" settings page to set a driver manually)
ERROR: Cannot setup device 1,1,0.
I have tried Unlocking the drive in VCDEasy but I have no idea where the CD Writer/Reader settings page is.
Can anyone help me?
Thanks, Carolyn
If you hit vcd then main...the cd writer is right above volume label. if you push setting then cdrdao, at the bottom you should see were you can put in your cd writer.
hope this helps also, how did you unlock I think I need to do that. Having problems when I go into the pages you need to, everthing is gray
hope it works
Chodaro -
After I found out how to Force the driver the cd unlocked. I just clicked on the Unlocd CD Writer button. I'm using VCD 1.1.5
I had problems with the greyed out area also and I had to use the forceaspi17 to make it work right.
Carolyn
Can't access my router's web page to change some settings
By Enowil in forum ComputerReplies: 17Last Post: 10th Jan 2012, 06:57 -
I get a "could not load codec settings" with Fairuse Wizard
By felix in forum DVD RippingReplies: 3Last Post: 29th Apr 2011, 11:10 -
TMPGenc DVD "add a note page" ?
By Spassvogel in forum Authoring (DVD)Replies: 0Last Post: 6th Aug 2009, 00:07 -
DVD writer/reader...unable to read DVDs
By maass in forum DVD & Blu-ray WritersReplies: 7Last Post: 9th Apr 2009, 11:08 -
Decrypter "Brute Force" mode can damage the writer, or produce ba
By Bruxo in forum DVD & Blu-ray WritersReplies: 5Last Post: 2nd Dec 2007, 15:26
