I just downloaded teo movies, one is an avi and the other is a divx..when I attempt to encode, I get an error stating that the file is unsupported...how do I fix that in order to proceed with the encoding?
Are you sure the download isn't corrupt? Can you play both movies perfectly?
Virtual dub can corect a corrupt avi
pen your avi in virtual dub,save the file as old format avi , use compression for both video and audio streams, in full processing mode.I am curious whether this will work
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>Try this: open the avi in virtual dub, save it as old format avi, using compression for both video and audio streams,and make sure you are saving in full processing mode.This has been known to correct a corrupt avi file. -
thankd for teh advice...i actually downloaded some divx codecs, installed them and now it works fine...converted using TMPGE and now its time to edit? is that difficult???
I am haveing this same problem and I also installed the divx codecs and it didnt help so maybe I got the wrong one or something were did you get yours ?
thanks
AutoGK: Unsupported audiotype! Here's what i tried.
By Moonwalker1982 in forum Video ConversionReplies: 1Last Post: 14th Feb 2009, 05:34 -
failure to convert flv to Avi file because of unsupported video codec
By 2thvideo in forum ffmpegX general discussionReplies: 10Last Post: 30th Jan 2009, 12:54 -
Best settings voor TMPG Express MTS Files to Divx Avi
By jeremyotten in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 8th Mar 2008, 09:36 -
TMPG DVD Author 3 won't open FVFW avi
By jasoncolz in forum Authoring (DVD)Replies: 0Last Post: 7th Dec 2007, 15:21 -
TMPGEnc Plus 2.5 saying unsupported??
By Suprman37 in forum Video ConversionReplies: 10Last Post: 12th Oct 2007, 17:51
