Hi all,
i am getting the error Cannot Find a driver to draw this non-RGB imaging format. Preview and histogram functions will not be available. and goes to caputer mode there though i have the huffey codec installed i do not see any codac listed except no compression dvsd. Please ehlp me to capture the vedio that can be used in cce to autor dvd.
Virtualdub doens't recognize DV devices. I looked at your computer profile and guessed that you're trying to input from DV, right?
I use DVIO, when capturing DV.
OR
You're trying to capture while operating Windows 2000? If so, you need to download a wrapper for Virtualdub. It's in the tools section to the left. Virtualdub uses VFW drivers, but Windows 2000 uses WDM drivers. The wrapper allows Virtualdub to capture under Windows 2000.
Windows 7, Virtual Dub (any Version), BlackMagic Intensity Pro = No Capture
By Digital-Overload in forum Capturing and VCRReplies: 2Last Post: 22nd May 2011, 11:57 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 14:48 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 16:36 -
Some questions regarding Virtual Dub
By smackyourfupa in forum DVD RippingReplies: 3Last Post: 5th Nov 2007, 07:00 -
Virtual Dub in asp
By dizzy123 in forum ProgrammingReplies: 13Last Post: 19th Sep 2007, 07:00
