I have 2 comps. Both with Xp Pro. I have adelphia cable and using webstar cable modem with usb and cat5 port. Usb works on both comps, but cat5 doesnt work on either comp. How do i set it up to have internet on both comp. Both comp have network card.
"Don't tell me to go to hell when you don't know what heaven is." – Yohji, Weiß Kreuz
“No one has the right to take the life of another.” –Rem Saverem, Trigun -
The easiest way will be to get one of those Cable/DSL routers and let it take care of it for you.
If you know enough basic networking you could also hook the machines up with a hub and let internet connection shareing give it a go, but if you do then the machine with the direct connection will need 2 network cards (unless your using a usb cable modem) and will have to be on when the other machine is on the internet.
Thats why the router is the best route for simple shareing. -
I use a D-Link DI604 router, and I would recommend it. It's $49.99 (Best Buy has a $10 rebate on it as well) and includes a built-in firewall, filtering options, and some other goodies.
Flay is right -- a router is much better than using a hub and having to leave one computer on all the time -
A very cheap solution available this weekend on sale after mail-in rebate from staples.
Long URL -- edited by vitualis
Share my Internet connection (like a proxy)
By themaster1 in forum ComputerReplies: 13Last Post: 26th Aug 2011, 00:00 -
How to find what programs connect to internet
By Tbag in forum ComputerReplies: 28Last Post: 10th Jul 2011, 16:29 -
Cannot connect to internet with my real IP?
By capman21 in forum ComputerReplies: 3Last Post: 10th Mar 2011, 17:58 -
Computer Wont Connect to Internet
By LCE in forum ComputerReplies: 11Last Post: 23rd Jul 2008, 14:47 -
Computer won't connect to internet
By DuBsTaR in forum ComputerReplies: 10Last Post: 16th Jul 2008, 17:00
