Does anybody know of any authoring software that uses avi's? All of the programs I have used use only mpegs or vobs. Most of the movies I download are avi's and I get tired of converting them.
Also, a few times I have downloaded a movie of the net, but when I try to put it on a dvd, it says it is over the size limit. The movies are onlyl about 700-750 mb, but when I try to make a dvd, it says they are over 5 or 6 gigs. Anybody know why this is?
1. Ulead DVD WORKSHOP:
http://www.ulead.com/dws/runme.htm
2. Ulead DVD MovieFactory 2:
http://www.ulead.com/dmf/runme.htm
Both programs will accept .avi files.
Jerry Jones
http://www.jonesgroup.net -
Although Specialist is correct in his recommendations, use them only if you really don't want to have quick results, and don't wish to fit too much on a DVD. Authoring packages that encode AVIs for you, tend to use rather basic, if not primitive, encoders that use too much bitrate to provide good quality. You will find that Tmpgenc or Mainconcept or CCE Basic will give you much better image quality at a lower bitrate, meaning you can actually double the content you can fit on a DVD. They will even be faster, well probably ...
The more I learn, the more I come to realize how little it is I know.
DVD authoring question...
By mjl1297 in forum Authoring (DVD)Replies: 8Last Post: 12th Mar 2011, 11:26 -
Question on authoring with sub folders?
By npereira in forum Authoring (DVD)Replies: 5Last Post: 9th Jun 2009, 23:56 -
Complex authoring question
By orloman in forum Authoring (DVD)Replies: 3Last Post: 12th Aug 2008, 17:11 -
A question on re-authoring
By teabagg in forum Authoring (DVD)Replies: 1Last Post: 22nd Nov 2007, 22:14 -
Another DVD Re-authoring Question
By videopoo in forum Authoring (DVD)Replies: 8Last Post: 14th Sep 2007, 03:40
