Hello,
I noticed a problem when trying to pull an encoded file into MyDVD to burn, when it said it could not find the file, but it was there.
Turns out, the encoded file, according to AVIcodec has a duration of zero for the one hour of D8 tape I captured using Windows Movies Maker.
The file size is 2.4GB.
The video portion is 0.0b, 4397kBps, 29,970fps, 720x480(16:9), MPEG2.
The audio portion is zeroes all the way across.
Previous to this one hour D8 tape, another D8 hour encoded without any apparent problems. Using the same settings in Wizard, the file came out:
video portion: 1.86GB, 4337kbps, 29,970fps, 720x480(16:9) MPEG2
audio portion: 181MB, 416kbps, 48kHz, 2 chan, MPEG1 audio layer.
A different one hour D8 tape yielded a M2V file plus a WAV file, again with the same Wizard settings.
Are these symptoms of something I should know about?
Am I going backwards here?
Should I be doing the audio separate? Should I not use the Wizard?
Thanks for your time.
ps. should this be in Newbie?
Results 1 to 1 of 1
TmpgEnc and MTS files
By tony_baruti in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 10:54 -
AC3 Files with TMPGenc
By PHNeedsHelp in forum AudioReplies: 3Last Post: 4th Nov 2009, 12:37 -
Need TMPGEnc Author help for .mts files!
By Woodserr in forum Video ConversionReplies: 4Last Post: 13th Jul 2009, 10:09 -
Pixelation in resultant video
By billgeo in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 1st Jul 2007, 20:43 -
Cannot open wav files in Tmpgenc
By deadlycow in forum Newbie / General discussionsReplies: 2Last Post: 23rd May 2007, 02:54
