Hello,
I am new to video recording somewhat, and have only made one video edited movie so far. I was wanting to do do something for my Dad for fathers day which is coming up:
He wants to get rid of his ancient (small) TV and SONY vcr that he has in his office, and just use a computer for video. He has a set of videos from a seminar that I was wanting to transfer to CDs for him.
I do not have a DVD burner, so was wondering what the best way to do this on regular CDs is? Should I use MPEG 2 or DIVX or something else? I'm mostly looking for a format that will preserve the VHS quality and fit the most possible minutes on a CD.
I will be using a Kworld USB 2.0 TV Box into a Toshiba 1.5GHz notebook, with 512mb ram for the video transfering.
Thank you for any help!
Sincerely,
Jed Smith
Thanks for the link, Tommy. After looking at that chart, does MPEG2 seem like the best choice? DivX would be cool for fitting lots on a CD, but then he'd have to always worry about having the DivX codec, right? I guess it's pretty popular, though, so maybe that would be worth a try...
Anyone have a resolution to use when capturing from VHS? I'd like to preserve what little quality there is, if possible.
Thanks,
Jed -
Well, once you install it on "Pop's" system, you can forget it. Once it is there, you never have to worry about it again. And once you see how good a DivX capture is, I am sure it will suffice as a good substitute for VHS.
Hello.
Should I use S-VHS cable for standard VHS transfer?
By Gibson's Squares in forum Newbie / General discussionsReplies: 11Last Post: 16th Feb 2012, 12:50 -
Newbie - Question regarding VOB to DVD transfer?
By Greggles in forum Newbie / General discussionsReplies: 5Last Post: 19th Oct 2010, 15:37 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 08:43 -
New problem with VHS transfer
By lgh529 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2008, 21:02 -
VHS Transfer Help
By chelleb1219 in forum Capturing and VCRReplies: 5Last Post: 17th Jun 2007, 16:40
