Are there any capture (would prefer hardware encoding) cards that has an audio input? Would prefer either toslink, coaxial or L/R. I will be connecting my satellite audio to it. I finally figured out with some help on this forum that the reason my captures was not getting any audio is that my card does not have any audio input.
Right now I have the audio connected to the Maudio DiO and can receive sound without having any capture software running. When I try to playback the captures I do not have any audio. This is the reason I am looking for a different card.
Thanks,
Results 1 to 15 of 15
Try WinTV-PVR250/350.
Link to 250:
http://www.hauppauge.com/html/wintvpvr250_datasheet.htm
Link to 350:
http://registration.hauppauge.com/webstore/hardware.asp#pvr350
Edit:
WinTV-PVR-350 also includes a hardware MPEG2 decoder and an S-Video output, so you can watch your recorded TV shows or home videos on your large screen video monitor or TV set! -
I have my HTPC now connected via DVI from my Radeon 9500 Pro to my GWII. Will these cards still be able to send the video through my Radeon 9500 Pro instead of the s-video output?
sound s like you need a tool called Tvtool this sorts out where and how your video is output and is particularly good at outputting to Tv including overscan etc.
He is asking about capture cards not tv out cards.Originally Posted by RabidDog
Not sure why you need a capture card with sound capability anyway.
If you are feeding the audio to the pc seperately just plug it into LINE-IN socket on your sound card. Then tell your capture software to use that as the audio source.
Fozzee -
The problem is that my satellite receiver has toslink and coaxial outputs. So I cannot plug into the line in which is mini-plug. I have tried several times to fine an adaptor that will do this, with no luck.
Check this site. I think this is the converter you are looking for. Toslink input to analog RCA output.
http://www.amabilidade2002.com/toslink.htm
http://www.amabilidade2002.com/toslink6.htm -
The Toslink is the small square fibre optic connector on the back of some newer audio and video equipment. It is used for Digital audio. Found a site in the UK that carries a PC audio card that has both inputs and outputs for Toslink and digital coax. Check out this site.
http://www.etcetera.co.uk/products/STA008.shtml -
I have the convertor already. The problem is the line in takes a mini-plug not a RCA plug.Originally Posted by MikeV
Will a toslink to mini plug cable transfer a PCM signal from my satellite receiver?
Reubenray
Check the link I sent before. If you look through their site you will see that they carry all types of adapters and cables there should be one in there that should work. Have never tried the Toslink , but I think it should carry the PCM data through the converter.
Also check your local electronics shop for a 1/8" stereo plug to stereo RCA plugs(i think this is the mini plug you are asking about).
TXpharoah What are you talking about?? Reubenray is asking about a converter for Toslink or coaxial Audio to 1/8" mini plug. -
MikeV
I did check those sites that you posted. Several of them has toslink to mini plug cables. I just wish I could find one locally in case it did not pass PCM audio. I could have sworn I have seen them at the Rat Shack, but after checking three different stores I have not been able to find them yet.
If I cannot get the cable to work I might have to decide to either get the Pinnacle PCTV Deluxe or the Canopus ADVC-100. I am just concerned about the USB connection not being as good as a PCI connection.
USB 2.0 Video Audio capture Card
By jj3502 in forum Capturing and VCRReplies: 0Last Post: 3rd Feb 2010, 05:09 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
How do i connect audio on capture card?
By GLE3 in forum AudioReplies: 11Last Post: 9th Mar 2009, 23:06 -
Help with VHS -> DVD using capture card (audio problem)
By dustin1 in forum Newbie / General discussionsReplies: 20Last Post: 8th Feb 2008, 00:27 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
