I have a question about using Ulead DVD Movie Factory 2... If i imported a DVD video or any video file, it creates a folder in my c:\....\mydocuments\Ulead Movide\2.0 and stores the temporary files in there. See my c: drive is only 10gig, and with winxp and other programs installed, it comes down to about 5 gigs. when DMF imports the DVD video already ripped (say from my g: drive which is 40gigs), it stores it in c: drive and works from there. if i try to add more video, it would fill up my c: drive and say the drive is full. now i want to change it to any other drive besides my c: drive, like d: or g: but it wouldn't. I try to change it in preference option to g: drive but still uses c: drive as temporary working space. i even went to regedit and changed the setting regarding DMF working directories... i am out of options. if someone could help me out, i would appreciate it very much.
It's a stubborn setting. The only way it seems to want to change is by bringing up the 'Capture video' screen, changing the 'Capture folder' path and pressing the 'capture video' button, it will now remember the capture path and write all the imports and capture files to that directory.
Note: just changing the capture path will not force the change, you have to hit the capture button.
Ulead DVD Movie Factory 6 Plus
By orientaldragon in forum Newbie / General discussionsReplies: 8Last Post: 2nd Apr 2011, 09:48 -
By Ragamuffin in forum Authoring (DVD)Replies: 3Last Post: 6th Oct 2009, 13:22 -
Ulead DVD Movie Factory...
By mmitchell_houston in forum Authoring (VCD/SVCD)Replies: 225Last Post: 23rd Oct 2007, 11:59 -
By koberulz in forum Newbie / General discussionsReplies: 10Last Post: 26th Jun 2007, 08:14 -
Ulead DVD Movie Factory 5 Plus Help
By sootylfc in forum Authoring (DVD)Replies: 3Last Post: 21st May 2007, 19:20
