Trying to build a SVCD I always get the same output:
**ERROR: EOF in WAV header
**ERROR: failure reading WAV file
INFO: [mplex] mplex version 2.2.1 ($Date: 2002/04/20 19:08:30 $)
INFO: [mplex] File /Users/kermit/Documents/test.m2v looks like an MPEG Video stream.
**ERROR: [mplex] Unable to open file /Users/kermit/Documents/test.mp2 for reading.
The result should be a .img but is a .m2v only.
Where's my fault?
Any ideas?
Martin
Aaaaaaaaaah!
You took me on the right lane.
0SEx told me audio track would be 1, but obviously it was 0.
I tried and it worked.
thx for superfast answer.
Martin
idkGuest
get the same error message (EOF in WAV header).
how do I find audio track?
when I click 'check' in ffmepg, get applescript error
idk
idkGuest
++ WARN: [mpeg2enc] 3:2 movie pulldown with frame rate set to decode rate not display rate
++ WARN: [mpeg2enc] 3:2 Setting frame rate code to display rate = 4 (29.970 fps)
++ WARN: [mpeg2enc] Generating dummy SVCD scan-data offsets to be filled in by "vcdimager"
++ WARN: [mpeg2enc] If you're not using vcdimager you may wish to turn this off using -d
a52dec-0.7.4 - by Michel Lespinasse <walken@zoy.org> and Aaron Holtzman
No accelerated IMDCT transform found
0 frames decoded in 0.00 seconds (0.00 fps)
INFO: [mplex] File /Users/idk/Desktop/DVD_SVCD/cb2.m2v looks like an MPEG Video stream.
**ERROR: [mplex] Unable to open file /Users/cassianyee/Desktop/DVD_SVCD/cb2.mp2 for reading.
Well,
the audio track from OSex says "1 Normal Audio (EN) [AC3 2CH DRC 44 KHz]" so I set Audio track to N-1 = "0".
but I still get the above errors?
your thoughts?
Thanks,
IDK
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 13:36 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 19:40 -
6ch Wav to 2ch stereo wav
By ranosb in forum AudioReplies: 12Last Post: 15th Jul 2009, 22:45 -
Installation Error: unexpected EOF while looking for matching `''
By thomashillard in forum ffmpegX general discussionReplies: 4Last Post: 24th Oct 2007, 16:59
