Hello im wonder how the hell i encode a xvid file as soon as i put it on TMPGEnc it crashes im sure you play around with the VFAPI PLUGIN but what goes where ??? and what priority do i need them
thanks in addvanced
Darren.
THE SOLUTION TO ALL YOUR PROBLEMS!!!!!!!!!!!
Just use the FOURCC changer from the Xvid codec pack!!!!
Put in both fields DivX and hit APPLY.(and not divx3 or anything else!!!!)
Now you can encode as usual with NO quality loss!
I have experience in encoding for a couple of years now, and believe me,
I know what I`m talking about. Forget all the guides with environmental changes in TempGenc. etc. Just do what I wrote above and all your XviD problems are gone.
Btw. use the ffdshow codec pack instead of Nimo (Nimo sucks!)
Any questions regarding encoding: mail me and I`ll try to help!!!!!!
Qeef.
"Stones rock" -
im using a k-lite codec pack
it use to work like untill i formatted my computer oh well ill try that cheers
hi
Ok newbie ere too , i cant seem to get Tmpgnc to except Xvid either it will encode the video only , but not the sound , says not audio supported ? can i do it ?
I dont quite understand the above method to be honest , i got Ffpshow but dont understand how to get it to work woth tmpgenc ?
Helpppppppppp
thx Paul
add me to your msn arctic2ltd@hotmail.com -
wish someone out there cud help me lol anyways there was a website on this site i went to which had the VFAPI PLUGIN and where to place them can any 1 remember that cos i cant 2 save my life thanks in addvanced
daz
add me to ya msn dazza193@hotmail.com -
Rite i sorted it my self this should work for you 2 @ discopaul
Open tmpgenc then you have to go into options > environmental settings, select the VFAPI plugin tab and put the DirectShow multimedia file reader at the top of the list. (priority 1) then close down and then tmpgenc shouldn't give you an error message anymore.
That worked for me
fixed it me self just playing around hehe
ACK!!!!
M'kay.
1) Use the 4cc Changer and make the audio and video say divx
or 2) In TMPG enviromental settings, make the FFDShow filter a 2 and everything else a 0, then XviD will encode piece of cake.
3) Can't encode the audio? What audio? Use GSpot to identify the audio. More than likely it's AC3 or VBR mp3. Neither of which TMPG will deal with. Read any number of guides for AC3 or VBR audio and TMPG (typically you do the audio seperately, using VDUB and Besweet, and maybe Headache for AC3).
4) Codec packs are EVIL, Nimo codec pack in particualr is very EVIL! Install just what you need (GSpot will tell you the codec).To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Or Goldwave for both MP3-VBR and AC3 audio. Load the Avi in Goldwave and save, simple.Originally Posted by Gazorgan"Art is making something out of nothing and selling it." - Frank Zappa
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 14:35 -
Does xvid cli (command line version of xvid) actually exist ?
By vhelp in forum ProgrammingReplies: 10Last Post: 29th Oct 2009, 15:18 -
help combining 2 xvid avis and 2 subtitles (srt) to 1 xvid avi
By hibbs in forum SubtitleReplies: 4Last Post: 14th Jun 2009, 20:05 -
How to encode an xvid file to another xvid and prevent video blocking?
By BlooderButcher in forum Video ConversionReplies: 5Last Post: 21st Nov 2008, 17:03 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 12:47
