This has happened before and I haven't found a solution to the problem, yet.
I downloaded an SVCD from USENET and after un-raring the files, got a Quicktime mpeg file. It won't play in QuickTime. If I convert it to a .bin file using VCDGear, I can burn it as a VCD but the movie is compressed into a square, plays on the left side of the screen with a black surround on three sides. What can I do to get the dimensions of the movie right?
BTW - I can't get the Windows version of VCDGear to work in VPC. I get a message saying that an illegal operation was performed and the prog. is shutting down.
Thanks for any info, Dave
check the size of the movie to see if it is SVCD compliant
use VcdimagerEasy LATEST VERSION under PC emulation to convert the mpg into bin (SVCD compliant, check the Toast option)
drop the resulting two files on Toast XA multitrack mode and burn
<font size=-1>[ This Message was edited by: major on 2001-09-21 12:06:18 ]</font> -
btw, as far as I know, the latest vcdimagereasy gui has support for outputting directly toast compatible tracks... no need to use fireburner anymore...
hvr, yep, you're right - btw it's me who asked delphi.stuff to include that Toast option in VCDImagerEasy.. and thank you again for developing it!
<font size=-1>[ This Message was edited by: major on 2001-09-21 12:07:11 ]</font>
trouble burning MPEG to DVD
By desert_dick in forum Authoring (DVD)Replies: 1Last Post: 19th Aug 2009, 14:22 -
burning and authored mpeg to dvd?
By just in forum Newbie / General discussionsReplies: 21Last Post: 12th Dec 2008, 09:06 -
MPEG burning
By aruwin in forum Authoring (DVD)Replies: 2Last Post: 20th Aug 2008, 05:02 -
No audio when burning a MPEG-2
By hostofsorrow in forum Newbie / General discussionsReplies: 3Last Post: 31st Dec 2007, 08:13 -
Edit mpeg and burning
By Mange Muck in forum Newbie / General discussionsReplies: 3Last Post: 16th Aug 2007, 14:16
