are there any MPEG Hardware capture cards which allow use of your separate sound card instead of only using the on board stereo inputs ?
I have sound card with optical audio in / out and would like to use that to capture from my Sky+ (UK) sat receiver / HDD recorder (which has S-vid out and optical audio out ) as some of our movie channels are now putting out in DD 5.1 and I'd like to capture that from the optical audio.
What I've seen so far with some cards, they either don't support it or it' a bit vague in the dscription...
Seems like a logical thing to want to do so I'd be surprised if no hardware allows this.
Have read about Dazzle, Snazzi, Vitec & Vidac products.
Vidac Tech Supp. told me that their Vmagic won't do it.
THX / Steve
Results 1 to 1 of 1
No sound in WME with USB capture card
By bomb jack in forum Capturing and VCRReplies: 2Last Post: 25th Feb 2011, 04:40 -
does capture of firewire use the sound card?
By Cazz in forum Capturing and VCRReplies: 4Last Post: 24th Jan 2010, 17:45 -
Question about difference between direct capture and sound card recording
By jimdagys in forum AudioReplies: 3Last Post: 16th Sep 2009, 10:09 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
No sound problem - internal tv capture card
By planetx in forum Capturing and VCRReplies: 1Last Post: 5th May 2008, 05:38
