yea thats basically the question, ive managed to make AVI's with it but ive gone off them now with my new dvd player that will play VCD's and SVCD's. i know i should look through the program more, but i couldnt seem to find anything. the box that comes up when you start it up gives templates but they were all for AVI. so yea, im wondering how can you make mpegs with premier?
Yes. If you have 6.5: File > Export Time Line > Adobe MPEG Encoder. Any kind of MPEG; DVD, VCD, SVCD.
6.0: File > Export Time Line > Save for Web.
This one is not for VCDs i think.
Very basic question...... how can I merge mpeg files and make a movie
By True Colors in forum Newbie / General discussionsReplies: 5Last Post: 30th Oct 2009, 16:45 -
How do I make an MPEG-2 dvd compliant file into a authored dvd?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 13Last Post: 12th Mar 2009, 15:10 -
After Effects or Premier
By milway in forum Authoring (DVD)Replies: 6Last Post: 17th May 2008, 15:16 -
how to make sure that your output format for autogk is either, avi, mpeg..
By sharmine in forum Newbie / General discussionsReplies: 1Last Post: 19th Sep 2007, 06:00 -
How to make DVD using MPEG Video Wizard DVD?
By nightcat in forum User guidesReplies: 1Last Post: 6th Aug 2007, 13:52
