  1. I'm encoding this movie I have and it's broken in have. I converted this avi in TMPGEnc and multiplexed and video and audio back together. Now i have this project thats completed in DVD MF LE 2 and I have about 11 chapters for the first half. After it's done processing the first have it comes up with an error that says something like "too many chapter frames for the amount of chapter". Do you know if this is a problem that occurred during TMPGEncoding or multiplexing or is it with DVD MF LE 2. Sorry if I wans't clear enough.
    Apr 2003
    Why can't you select both halves at the same time. I do
  3. I'm not really following what you are saying. I can select both.
    That's not the problem. The final process is where i'm having the problems. While it's most likely creating the IFO files cause it has to do with chapters and I have the fully processed VOB files in the VIDEO_TS folder.
  4. I suspect it's a problem associated with the TMPGEnc multiplexing.
    I created a multi-chapter project in Ulead DVD MovieFactory 2 just today and it worked like a charm.
    I personally recommend to other users of the software that they use the Ulead MPEG.Now encoding engine included in DVD MovieFactory 2.
    It seems to result in far fewer problems.
    Jerry Jones
    http://www.jonesgroup.net
  5. Thanks for the response. I'm guessing that's the problem too. I did this in TMPGEnc cause I believe it's a far better encoder. If it comes down to it though I'll go ahead and do the whole thing in Ulead. I just remember the output from Ulead on my DV home videos. Okay on standard sets but on a plasma it was terrible. I'll give it another try.
