Results 1 to 10 of 10
  1. hi all,
    When trying to put a divx film to svcd using virtual dub and DVD2SVCD i got the following message at encoder level
    "CC encoding error
    Vidéo check sums is different from that previous pass
    source vidéo data or time code may be different
    please check video tape or the information file
    informations: current: check sum = 00826123
    precious: check sum = 0081ed39
    Can someby explain what it means and what to do
  2. strange i have had the exact same problem!! it has happened with a cople of divx movies (bitrate etc different for each one!)
    what version of CCE are you using (i use v 2.50). i will keep track of the prob as i need to solve it also!
    1)Why Not Overclock a little?! speed 4 free!!!!
    2) If your question has anything to do with copying PS2/PC/XBox games, find a more appropriate website
  3. Hi freak
    I use cce 2.50.1.0
    tanks for interest
    gema
  4. bump!
    Mar 2002
    Manchester, UK
    This is a known problem with CCE 2.5
    As Adam said in another thread once - Check out this topic at doom9 http://forum.doom9.org/showthread.php?s=&threadid=21859 and look at question 27.
  6. wow, i sure hope it works, i will try it out this very minuite!!!! thanks a lot man!!! i will post here if i get a sucessful output!!!!!
  7. I try it
    I don't have the prob anymore but only 25% of the vidéo file is converted
    when looking the result on my dvd reader i got the audio but no vidéo just a message saying " attemting to read from 0a1028a000"
    i don't know what to do now
    Tanks for support
    Mar 2002
    Manchester, UK
    I'm guessing that's an AVISynth error. maybe it's due to a corrupt AVI?
    Have you used VirtualDub to check for bad frames? If not try that.
  9. hey grumpy,
    Yes I check for corrupted file and i don't have
    On top, i try replacing cce by tmpge vbr 2 pass and the result was good.
    Probleem i cannot predict the finish size and got just a little too much to fit it on 1 cd.
    Don't now what happen with cce
    Tanks for support
    Géma
  10. I think this occurs because you are using an old datafile. Try deleting or renaming your file, it works for me!
    Simon
