Can someone pls. help me to get video from Dish PVR 501 to computer. I can't use AIW from Radeon as my computer does not support, due to IRQ issues.
Please provide us with more information about your computer and the Dish PVR501. Provide us with at least OS, capture card, capture software, ports, CPU, MB, and type of output from the dish PVR. Also where is the computer and DishPVR located, same room, different rooms, or several miles apart?
My crystal ball broke yesterday
My computer is Pentium III, 1.4GHz, 384 MB RAM, 100GB HD
OS is Windows XP
capture card is Radeon 7500
type of output from the dish PVR - don't know. Need your help here.
Also where is the computer and DishPVR located - different rooms.
Cheers! -
You need have your DishPVR lot closer to Compture or other way around in order to user the S-Video or Composite.
Check on the back of the Dish PVR you should have outputs for composite or S-Video and audio. Use high quality video and audio cables (less than 300ft) to from the Dish PVR to the input of your capture card. Do not run the cables next to power cables(extension cords,etc) this will cause interference.
Will my computer be able to handle a Hauppauge HD PVR?
By FinalGypsy in forum Capturing and VCRReplies: 17Last Post: 26th Sep 2013, 09:51 -
SKY hdTV > Hauppauge HD PVR > Computer
By JBD007 in forum DVB / IPTVReplies: 2Last Post: 5th Sep 2011, 08:05 -
HD PVR - Audio not synced with video
By lacywest in forum Video ConversionReplies: 5Last Post: 29th May 2010, 10:20 -
Hauppauge HD-PVR HD Video Recorder
By MooMoo in forum Capturing and VCRReplies: 2Last Post: 16th Dec 2009, 17:54 -
PVR 150 won't do VCD on new computer
By darwin-t in forum Capturing and VCRReplies: 9Last Post: 27th Mar 2008, 15:29
