I'm trying to create a dvd from home video. I think I've read about every help article on this site but I still have a problem.
I record the video in avi.
Then I convert it with tmpgenc to mpeg2 dvd format.
I am using the settings that come with the dvd configuration file in tmpgenc.
Then I use Mydvd to write it to dvd.
The clarity is great until someone starts to move and then there's this kind of a blur type of digitized thing going on.
I've tried changing the tmpgenc so that it uses the motion search precision of high and the quality actually got worse.
I could really use some help. Otherwise I'm going to spend a fortune burning test dvds.
To start with, why don't you buy a +RW or -RW disk? Will save you the fortune in burning disks just for test.
Regarding the low quality, two things grabbed my attention.
First, Mydvd re-encodes the video. So, whatever you do with Tmpgenc is irrelevent and redundant. (Actually, I would argue that MyDVD is redundant. You should try Tmpgenc's DVD authoring program).
The blurry effect you mention - and the fact that it's a home video, brings to mind field order problems. The source video is interlaced. The issue is: Are the odd scan lines first or the even scan lines? If you get it wrong, you get a blurry effect in motion and panning. Of course you can get a "blurry" effect for a whole lot of other reasons.
When encoding in Tmpgenc, check the Advanced settings and switch the value for the Field Order (Field A / Field B).The more I learn, the more I come to realize how little it is I know.
Blurry video...
By Delora in forum Video ConversionReplies: 4Last Post: 17th Dec 2010, 11:23 -
blurry video
By drew68 in forum EditingReplies: 0Last Post: 6th Dec 2010, 12:12 -
Blurry Video
By homantam in forum Latest Video NewsReplies: 1Last Post: 24th Feb 2010, 07:34 -
Text in video - Good with WinAVI, blurry with Winff (.flv to mpeg/DVD)
By Paker in forum Video ConversionReplies: 25Last Post: 13th Sep 2009, 12:07 -
NEWBIE - Converted and burned XVID to DVD -- Blurry/boxy on TV
By baldieme in forum Newbie / General discussionsReplies: 4Last Post: 7th Feb 2008, 17:47
