Is it possible to capture to a firewire, or USB 2 drive and have the same results as my internal. NO dropped frames etc....
Thinking of buying another drive and external adapter to make the drive external. They have 2 versions, firewire or USB2.
It depends on how you are capturing.
If you are using DV, or mpeg you will be OK. If you are using uncompressed RGB, then you will need to find another way.Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
Yes firewire drives are fine.
I've yet to drop a frame from DV.
Capturing VHS to External Hard Drive...
By the colonel in forum Capturing and VCRReplies: 10Last Post: 2nd Nov 2009, 19:34 -
Vobsub on external drive
By htm in forum SubtitleReplies: 2Last Post: 4th Aug 2008, 13:04 -
Garbled frames + sound hickup when capturing to external drive
By ByronFortescue in forum MacReplies: 5Last Post: 21st Apr 2008, 06:28 -
Videos stutter from internal drive, but okay off external drive
By ruggrock in forum Software PlayingReplies: 7Last Post: 22nd Jan 2008, 13:17 -
Is It Possible to Make Multiple Drive Images on One External Hard Drive
By drstew in forum ComputerReplies: 17Last Post: 24th Nov 2007, 08:47
