  1. i have this vcd with menus at the start having some options like
    1) play movie
    2)play song 1
    3)play song 2
    4)play song 3
    this is done without any different file , what i mean is that the vcd only has one dat file and the menu is timed
    how can i do that usually u have different files for different option
    but this one how do u do
  2. You could do it with entrypoints... You probably need to have a closer look at your VCD. I would bet that there are a few files under the SEGMENT folder as well.
    Regards.
    Michael Tam
    w: Morsels of Evidence
