Does anyone know what editing program lets you import .m2v and .ac3 files to edit? Vegas 4.0 doesn't reconize those files, Adobe premeire 6.5 reconizes .m2v but not .ac3 files. Does anyone know if Avid or any other software will let you import those files for editing.
maestro is not a editing program but you can cut m2v files in it ..
vegas will reconize mpeg file if you mux them first (not ac3 though) - it will also rerender ..
vitec dvd tools will edit m2v and ac3 files (cut apart ac3 only) with out re-render.
goldwave will edit ac3 if you install the ac3 codec found in tools - it will render it though ..
ulead something will edit mpeg files with out rerender i think - not ac3 though .
you can convert ac3 to wav and edit in vegas or whatever along with your muxed m2v file (mux in tmpgenc with out any audio as a program stream)
you can edit m2v files in virtual dub mod -- not ac3 -
adobe will rerender m2v file ..
avid doesnt have any program that will edit ac3 and only by frame serving will any avid products edit m2v ... i assume you mean avidDv otherwise you are in a whole different ball game .. -
Added in the newest version, lowered their price to $129 too.Originally Posted by BJ_M
HD .m2v and .AC3 Help Needed Please
By lovelylisa in forum Video ConversionReplies: 40Last Post: 29th Jun 2011, 08:20 -
Is there a program to edit HDDVD like Clown_BD can edit Blu-ray?
By c627627 in forum Authoring (Blu-ray)Replies: 0Last Post: 3rd Jan 2011, 23:35 -
m2v + ac3 problem?
By just in forum Newbie / General discussionsReplies: 2Last Post: 21st Oct 2008, 17:24 -
edit m2v files?
By SUPERIOR in forum EditingReplies: 2Last Post: 16th May 2008, 02:42 -
Authoring program? (m2v's/ac3's/mpg'sVOB's)
By RobAdam in forum Newbie / General discussionsReplies: 1Last Post: 11th Nov 2007, 06:53
