hi!
i use tmpgenc with toolame for sound
the sound quality is just not good enough, especially the piano in the movies sounds horrible...
in tmpgenc there is 224 kbs and cannot be changed, right?
is there any other way to get a better sound? i dont mind sacrificing 200 kbs of video for a better sound...
thanx!
hi majkol,
what source are you encoding from? (especially the audio obviously)
I only ask 'cause if the source isn't that great, throwing extra bitrate at the audio won't improve things much.
I've always been quite impressed with tooLame's mp2's at 224kbps, but it's very subjective as to whether you think the compression leads to a big drop in audiable quality.
cheers,
mcdruid. -
majkol,
that's sort of what I meant; so you're not ripping from DVD?
If you're talking about encoding downloaded avi's (DivX, Xvid etc..), you're not all that likely to improve the sound.
The sound on a lot of DivX's is mp3 (or maybe ac3) - and is often not that great in the first place.
How do your avi's sound before encoding? You're not going to be able to improve it much from there, aside from the volume/level.
One thing to watch out for is that you normalise the wav, and preferably before encoding with tooLame. If the source is quiet (which it often is with downloaded avi's), that will obviously make it sound worse, and give tooLame less of a chance to do a good job on the compression.
do you have any audio editors? e.g. Soundforge, Goldwave, CoolEdit etc..
cheers,
mcdruid. -
Hi,
You can always change the audio bitrate in TMPGenc unless you used one of their templates. In that case select load for a new template an load the "unlock" template in the extras directory. Nothing is changed in the setting, everything is just changable this way
Greetz,
pSyChO dAdThe difference between genius and insanity is only measured by success ! -
i think i know whats the problem: Xvid (again
yes, with divx works ok, but with xvid not only the jerkiness, now also the audio is bad(not so bad that you cant watch it, but worse than divx's)
maybe just with this xvid(btw.. the ring:0) tho... it has ac3 sound and originally was very quiet but i changed that in goldwave
druid: i know i cant improve the sound, it can only get worse, but this time it was too bad
psycho: thanx, might try it, but i dont think so few more kbs will help
Sound quality of Tmpgenc: Is it that bad?
By Banleno007 in forum Video ConversionReplies: 3Last Post: 15th Feb 2012, 22:10 -
Very Poor Video/sound quality
By mikey56hernandez in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2011, 21:27 -
Encoded BD movie sound quality
By GeeForce11 in forum Blu-ray RippingReplies: 0Last Post: 15th Dec 2008, 09:05 -
How to improve the sound quality of this video?
By awaisuk in forum EditingReplies: 2Last Post: 19th Nov 2007, 23:15 -
sound quality
By ecos in forum Newbie / General discussionsReplies: 10Last Post: 1st Jul 2007, 18:34
