hello
i'm a complete newbie asking a very embarrassing question.
I have a movie in .ogg(.ogm) and i'm trying to convert it to vcd. How do I rename the file as an avi? I have windows xp home, so when I just rightclick and rename it as movie.avi, the actual name is movie.avi, but the type is still .ogm
newbie in need.
please help
when you change the file to avi does XP ask if you won't to change the file extension ? If not you need to untick "Hide extensions for known file types" I think
Tools>Folder Options>View. -
in the future you should do a forum search for past topics on your problem for instance typing in ".ogg convert" gives many threads, this is one of them
https://www.videohelp.com/forum/viewtopic.php?t=155349&highlight=ogg+convert -
Hi there, thank you so much for ur info, it worked!!Originally Posted by BuMpErS
renaming captured DV from metadata
By loady in forum Capturing and VCRReplies: 2Last Post: 4th Jan 2012, 03:29 -
Renaming video files?
By c4bdriver in forum Newbie / General discussionsReplies: 5Last Post: 19th Mar 2011, 09:09 -
Automatic subtitle renaming
By notme1 in forum SubtitleReplies: 2Last Post: 5th Apr 2010, 14:49 -
Crash on renaming AVI files
By Captain315 in forum ComputerReplies: 10Last Post: 7th May 2008, 06:05 -
bulk/auto renaming
By chewie8008 in forum ComputerReplies: 7Last Post: 18th Feb 2008, 18:11
