my vcd files ".dat" and recently have "block" which now cause the the picture unclear and that was this problem occur last time , there is any solution to fix this problem sorry i 'am newbies and i'can't copy contain of my cd to my hd.
dl my template and doc file explaining tmpgenc thoroughly in the tools section on this site. the name's ShiZZZoN, good luck. I make movies as long as 2 full hrs without blocks, and if you understand everything i put in the doc file, you can too
Cyberhome 300 problem after playing VCD discs...
By MrCairo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Mar 2011, 17:57 -
DVD to VCD problem
By c1steady in forum DVD RippingReplies: 12Last Post: 14th Sep 2008, 18:19 -
Problem in VCD on WinAVI 9.0
By WhitGer in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th May 2008, 04:29 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 20:27 -
How to fix Audio problem with vcd authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 6Last Post: 16th May 2007, 11:20
