I have a new Powerbook G4, and am trying to learn to use it in the place of my old friends Virtualdub and TMPGEnc.
I want to export my iMovie project as .mov or avi, then use *something* to convert it to mpeg-2, but I need control over the bitrate, so iDVD is out for me.
I thought DVD Studio Pro would let me do this, but somebody here told me "no."
What should I do?
Andy![]()
Quicktime with the Mpeg2 plug in will do a good job that is what I use, it will give you a .M2v file and an AIFF and then use apack that comes with dvd studio pro to compress the audio file.
to bad quicktime did not do this for you, cause it estimates the file size you will get with the different bitrates but it does it with the uncompressed audio file. Does this make any sense, what ever.
Quicktime does it fairly quicky too, but it take over your whole system while it does it.EarlyGrace -
if I create the m2v and aiff file this way can I burn them to a data dvd-r and take them to a PC to work on?
(am waiting for DVD Studio Pro to come in the mail)
Andy
ps -thanks for the reply -
doesn't the quicktime mpeg-2 plugin come with DVDSP? that's where i got it.
there is a free encoder called ffmpegx which will do the job, but it will take a lot longer than quicktime.
http://homepage.mac.com/major4/
-MarkSwim with me
And we'll escape
All the trouble
Of the present age
Finally free -
and as for actually calculating the bitrate.. take a look at the bitrate calculator found on this very site.
btw you'll want your AC3 file to be 192-224kbps if it's a standard 2.0 track, which i'm sure it is.
-MarkSwim with me
And we'll escape
All the trouble
Of the present age
Finally free -
Strange! looks alot like another post where I suggested the same course of action!
oh well
ffmpegx also has a bitrate calculator built into it that works nicely.
Getting top quality Kbps from streams using variable bitrate screen control
By jilly in forum Video Streaming DownloadingReplies: 7Last Post: 1st May 2014, 16:42 -
How 2 control video bitrate using ffpreset libx264
By lindylex in forum Video ConversionReplies: 7Last Post: 3rd Jun 2010, 16:52 -
What software will convert my AVI files to something I can read in iMovie
By Quinn82 in forum MacReplies: 8Last Post: 12th Feb 2010, 17:38 -
what software converts to DVD with manual video bitrate control
By perfection in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jun 2008, 13:09 -
AC-3 bitrate limit on Apple TV?
By InsanelyOne in forum MacReplies: 0Last Post: 8th May 2008, 11:18
