  1. The Pan E30 manual says that the recorder can record in anamorphic on DVD-RAM. Will this work?
    1. Set all region player to 16 x 9
    2. Play anamorphic pal dvd -sending it to the recorder which is recording onto DVD-RAM
    3. Play back the DVD-RAM recording with the recorder set to 4 x 3
    4. Will the black bars(letterbox) appear on a 4 x 3 tv?
    5. Copy the letterboxed DVD-RAM to a dvd-r using two recorders.
    6. Will you get a letterbox dvd-r that will play letterbox on a dvd player hooked up to 4 x 3 tv?
  2. Try and lets us know
