  1. There are some British television shows that I just know will never be released on R1 DVD and I was wondering if there was any way I could rip the R2 PAL discs and convert them to NTSC? Any suggestions? Thanks.
    Dec 2002
    Texas USA
    Rip disc with DVDDecryter.
    Open files in DVD2AVI.
    Feed into TMPGenc and re-encode to NTSC.
    Remake your menus.
    Burn disc.
    Watch new NSTC movie.
    I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored.
    Boulder, Colorado
    Try this trick. I have successfully ripped and converted sereval UK issued DVDs to play on many different US only/ non firmware upgradable DVD players. after ripping the contents to the HD using Smartripper 2.41, i used IfoEdit .95 to remove the region code restriction and replaced the PAL header with NTSC headers. Them Burn them onto a 4.7gb DVD+R. So far have not ran across a DVD player that will not play them.
  4. Member marvel2020's Avatar
    Mar 2001
    Vorlon Home World
    Question ?....
    " Why bother at all, if your DVD player is Region Free/Multiregion then it should play them regardless of where they come from. "
    I don't bother Converting NTSC 2 PAL because my DVD Player will play NTSC DISC's on my PAL TV.
    I Have Always Been Here
    Toshiba Regza 37Z3030D, Toshiba HD XE1 + EP-10 ( Both Multiregioned), Samsung BD-P1500 Blu Ray. OPPO DV-983H
  5. Yes, BUT have you ever tried to play PAL on a NTSC TV?? Different story...
  6. I have successfully ripped and converted sereval UK issued DVDs to play on many different US only/ non firmware upgradable DVD players. after ripping the contents to the HD using Smartripper 2.41, i used IfoEdit .95 to remove the region code restriction and replaced the PAL header with NTSC headers. Them Burn them onto a 4.7gb DVD+R. So far have not ran across a DVD player that will not play them.
    More details please. I would love to do that to many Region 2 DVD's.
    Boulder, Colorado
    We consumers in America do not have the luxury of a more open market. The US is dictated by greedy CEOs, Politicians and many extreme laws like the DMCA, copyright protection. The more laws you create, the more outlaws you have.
