  1. Ok.. i want to burn the movie heist and lose the least quality possible..
    when i delete the french track it comes out at 4.43gig..dvd shrinks only option is to shrink it to 3.90 is there a program that could help me to just shrink the dvd about .05 gig or .06 gig ..
    any help would be GREAT
    -BEL
  2. DVDshrink is free so the options are a bit limited.
    If you want a better fit use DVD2one (not free)
  3. Just do a custom compression in DVDshrink and with a little effort you can get the file size to what you want.
  4. i did i deleted everything and it is 4.43 gig..ill try it in dvd2one
  5. Crop the beginning of the movie (the garbage before the actual movie starts - what do you call them anyway?) and maybe even part of the closing credits. Hopefully you've cut enough to get it under 4.38GB.
    See Mr. Bass' DVDShrink guide for more info.
