Does any have a sugestion? My Vitec DCM Card can't capture MPEG2 in a resolution higher than Half D1 352x576.![]()
I run it with a P4 2GHz Celeron on an ASUS P4B533 with Matrox G450DH32 on WinXP, so there should not be a problem with the CPU Power and/or the OS.
MPEG1 and MPEG2 runs pefectly in an resolution up to half D1. If I want to capture in a higher resoltuion the picture begins to flash to green and jumps around.
Best regards.
Results 1 to 1 of 1
Capturing From VHS Via VirtualDub Produce Strange Result
By max20d in forum Capturing and VCRReplies: 0Last Post: 8th Oct 2010, 22:55 -
Very strange VHS capturing problem..
By Veepa in forum Capturing and VCRReplies: 5Last Post: 3rd Apr 2010, 04:39 -
Strange sounding bass like noise when capturing from VHS. Help.
By Bricktop in forum Capturing and VCRReplies: 3Last Post: 9th Feb 2009, 09:21 -
Strange issue with audio capturing. Video is fine.
By m33ts4k0z in forum Capturing and VCRReplies: 0Last Post: 6th Nov 2008, 17:18 -
IRE, capturing and some really strange stuff
By binister in forum Capturing and VCRReplies: 19Last Post: 5th Jun 2008, 00:52
