  1. I have many problems with this sw when I re-encode a movie. If I chose the first re-encode level, when play the movie on my PC is all ok (Progressive Frame?), but if I put the same DVD on my Sony DP735 (Interlaced Frame?), in many frame appear pixel block of previuos frame or follow frame. Somebody have the same problem?
    THANKS
  2. I have used this software twice now and it seems to work for me okay, although i did use DVD Decrypter to rip the DVD instead - have you tried that?
    Thx in Advance!!
    Dec 2002
    Texas USA
    Yes. Similar issues. I've dumped DVDshrink until it gets an update. Great program, but still some problems. DVD2one for now.
    I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored.
