  1. Anonymous
    Guest
    how does "join" work? i want to join two (or more) .avi files, how do i do it?? is "join" only for joining video and sound?
  2. "Join", joins two mpeg files, or avi files. Select the two files to be joined in the two small input fields in the Tools tab. In 0.0.7 I'm slightly revamping the Tools interface so as it'll be simpler to use. Also I'm improving the AVI Join routines.
  3. Anonymous
    Guest
    uhm...."The Two Towers" becomes 56 Mb?? When both cd's are around 700 Mb?
    You're sure this should work? I did what you said - selected each file in each small window in the Tools tab. Then I selected "join", and pressed "go". Yess. 56 Mb...........
    Any other tips?
  4. As said above, I improved the Join routines in 0.0.7 (which should be ready in less than a week).
