I have an MPG, but the problem is the sound is okay at the start then suddenly goes very quiet for the rest of the movie (the sound is still there, but much lower). How do I raise the sound level, or normalize it?
Thx in Advance!!
Besweet will normalize sound for you. However, there is a difference between low audio in a video and low audio on tape from improper microphone adjustment. One can be corrected and the other has little hope of sounding good.
What is the source? I've never heard of that problem with a DVD source, but have heard of it with a CAM.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Erm... it was a donloaded video, so I am not sure.
I'll try BeSweet - is there a guide or a how to about?Thx in Advance!! -
Hmmm got the BeSweet GUI but still cant figure it out. Any help or other suggestions?
Thx in Advance!! -
you can use nero wav editor.
but you will have to convert the audio againHELL AINT A BAD PLACE TO BE
Low Sound Output After Adding .ssa to .avi
By edlimym in forum SubtitleReplies: 4Last Post: 12th May 2010, 08:02 -
Low sound in rear speakers.
By madman1987 in forum AudioReplies: 5Last Post: 24th Nov 2008, 13:44 -
low sound after burning to dvd
By ymurf in forum Newbie / General discussionsReplies: 3Last Post: 3rd Feb 2008, 15:59 -
LOAD CLICK AND LOW SOUND at join of 2 avi xvid ac3 using vitualdub
By hawklight in forum EditingReplies: 0Last Post: 15th Jul 2007, 09:44 -
editer shows 'no sound', mpg plays with sound
By oldvideote in forum EditingReplies: 3Last Post: 7th Jul 2007, 09:01
