I downloaded 4 divx files from a reliable source. The sound is out of sync on all of them so I guess whoever ripped them is to blame.
My question is this, can I do anything to re-sync the audio. There are no bad frames, I checked with vdub. The audio is about 4 seconds ahead of the video.
Does anybody know how to resync the audio or what programs I may need?
I find it hard to believe that someone would encode and not check for that. What audio codec are they using? if it's a fixed 4 seconds, that's easy enought to do. Strip the aduio out with vdub, run through besweet and clip/pad the front and pad/clip (the opposite) the rear then re-mux in VDUB.
Fixed sync issues are pretty easy to do, the hard part is getting the exact amount of offsett. I've had to adjust 5 times once to get exactly in sync, took maybe 20 minutes total (you can preview in vdub, don't need to actually re-mux until correct)To Be, Or, Not To Be, That, Is The Gazorgan Plan
Increasing Audio volume on AVI/DivX/Xvid with AC3 Audio
By Spacedementia87 in forum User guidesReplies: 21Last Post: 24th Dec 2021, 07:21 -
question about demagnetizing audio head on VCR to improve audio
By jimdagys in forum Newbie / General discussionsReplies: 3Last Post: 29th Aug 2008, 16:47 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 18:59 -
DivX question
By didikai in forum Newbie / General discussionsReplies: 11Last Post: 18th Jun 2008, 20:22 -
Converting Divx w/ Vorbis audio to Divx w/ MP3
By tachyon2u in forum AudioReplies: 3Last Post: 23rd Feb 2008, 23:35
