Have been using DVDBackup>DVD2OneX with good results. I have run into one disc that simply won't "work' with DVDBackup. Have downloaded OSEx but having trouble understanding where to go next. As far as output goes I assume that I would want to use the "DVD Folders" , or do I use the progressive stream option? The disc image option does what for me? I assume again it would just create a disc image of the DVD but is it also decrypted? What is the most straight foreward workflow to go from OSEx>DVD2ONE>burn?
If there is a tutorial on this somewhere can someone direct me to it please.
Thanks in advance
Rick
Actually you want to choose DVD FOLDER
I have a tutorial at home on it, but not with me at the moment. You can either wait until i get that up on here! or do this.
Pulling from memory here! so it may be a little off.
Load the app, and slect your dvd you want to backup.
Each of the little tabs shows you information on the movie
title, chapters, angle, video information audio information and you have your output options i think thats FMT?!?
Just choose DVD FOLDER and click BEGIN
that will copy the dvd into a VIDEO_TS folder in your HD which you can then run though dvd2one
video tutorial?
By greatveemon in forum Newbie / General discussionsReplies: 4Last Post: 12th Jan 2011, 07:20 -
New myDVDEdit tutorial
By myDVDEdit in forum MacReplies: 1Last Post: 17th Apr 2009, 20:14 -
avisynth tutorial
By pitaridis in forum EditingReplies: 1Last Post: 2nd Feb 2009, 06:46 -
EAC tutorial
By kippard in forum AudioReplies: 4Last Post: 25th May 2008, 03:06 -
Camcorder Tutorial??
By Ray & Paula in forum Newbie / General discussionsReplies: 1Last Post: 26th Mar 2008, 12:42
