I made just test disk from SVCD video file. My standalone DVD player dont play SVCD. Now i managed to make this disk what has VCD header . And it plays and show otherwise picture ok, but it plays in pauses. second to couple seconds or so. Just askin advice if there is anything to do
My DVD player is Finlux DVD F-2101 same as many LG s like DVD-3000E or Salora DVD S-1100
Probably not. It simply doesn't like the header trick. You'll either have to upgrade your player to one that does, or stick with VCD.
Impossible to see the future is. The Dark Side clouds everything...
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 19:40 -
VCD Aspect Problem. Header says 352x240 but WMP says 522x240!
By 201flyer in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Jul 2009, 16:21 -
dvdplayer on pause
By steplock in forum DVD & Blu-ray PlayersReplies: 5Last Post: 15th Jun 2009, 15:05 -
Can you pause in MKVEtract?
By Maikeru-sama in forum Video ConversionReplies: 0Last Post: 30th Jun 2008, 08:55 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54
