Hi all![]()
I have just bought a firewire card and am not sure how to install it.
The instructions say it can get power from the PCI slot or by moving a jumper on the card from the power supply. How do I know which one I need to do?
I have installed it with it set up to get the power from the PCI slot. I have downloaded the trial versions of ULead Video Studio and also Pinnacle Studio 8. With both lots of software I get an error message saying no device is connected.
My camcorder is a Canon MV600.
I am sure the firewire card is fitted correctly because SiSoft Sandra lists it as been so.
Any thoughts
KD
Results 1 to 25 of 25
Come on someone must be able to tell me how to install a firewire card correctly.
What brand Firewire card do you have? Try the manufacturer's support page for hints and suggestions.
Doesn't the card come with a driver CD? Make sure you install the drivers. Forget about Sandra...check in Device Manager. If it's registered there properly then that's what counts.
The driver CD should have some kind of application software on it...mine came with Sonic MyDVD and ArcSoft Showbiz. Use the apps your card came with before you try anything you downloaded from the Net. -
Try this; shut your computer down. Plug your camcorder in, turn it on, connect the firewire. Boot your PC. See if it now sees the camera? The firewire isn't powering your camcorder, so pci-power shouldn't matter.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
hmm -- your profile says you are using winme ...
that may be a problem (im not sure) , but i would upgrade quickly to win2k or XP before trying to sort out anything .. -
Thnks for the replies-much appreciated
The card is an InnoVision DV-1000LE, i couldnt find any useful information on their website. No software came with the card.
I have had a look in device manager and my camcorder is listed so does this mean it is installed correctly? There is no driver for the product installed and I have searched for one without success.
No further forward
Any more thoughts
KD -
dont know about winme but DON't install a driver for win2k and xp even if it came with one ..
Turn on your PC, after it boot plug the camcorder, ME should say something or make a noise telling you that it found the Camcorder.
Some Day I will….. -
Mando
If you mean plug in the firewire lead to the camcorder with the computer up and running then it does nothing.
But like I said - in device driver it is listed as Canon MV600. so the computer recognises that I have a camcorder connected?
Maybe it is a software fault with the editing software?
KD -
BJ_M is rigth.
It is posible for you to replace the OS for a real one.....
Win2K or XPSome Day I will….. -
Do you have a friend that has a PC with a different OS than yours?.
If the answere is "Yes" them yo can test your Firewire card in that machine.
if the Firewire card works, them you know what to do.....the OS
Thanks for the replies everyone.
I am giving up for tonight, just cant get to grips with why my computer says I have a camcorder connected but the editing software doesnt recognise it. I am not sure if it is a new model of camcorder and maybe the software doesnt recognise it, is that possible?
Logically if device manager says a camcorder is connected then it must be the editing software. This seems strange that it is the same with two different programs, bearing in mind that if this is the results which I get with the trial versions of the software then it doesnt exactally make me want to go out and buy the full versions!
I may be totally incorrect about this of course since I am a bit of a novice with computers
Thanks anyway
KD -
Ahhhhhhhhhhhh
Eventually found it according to the Ulead website camcorder compatability list
http://www.ulead.com/vs/compatibility.htm
My camcorder is not supported, I can only assume that the Pinnacle Studio 8 software is the same.
No further forward if this is the correct. What editing software is compatable with my camcorder ???????????????????????????????????????????
Have I made a bad buy here??
Any suggestions would be appreciated
Cheers
KD -
Some Day I will…..
Download ScenalyzerLive...that should work with your Firewire card and camcorder.
Your camera is the UK equilivent to the US zr60mc camera. All of the functions are the same but the default format is set up for Uk video systems.
When I first tried to get my zr-series camera to talk to the PC I had a lot of trouble. many of the downloadable programs are not updated to work with these cameras, but the purchased versions seem to work well when you register them and download the updates. (I've done that with both the Pinnacle and the Ulead products).
Before I invested in the commercial software I found DVIO over in the tools section of this site and it connected to the camera on the first try. I used it to download 3 full tapes and eventually used the output from DVIO in the downlaodable version of Ulead VideoStudio.
I suggest trying the DVIO freeware before investing in any other packages.
Good LuckOnly 3 things are certain in life... Death, Taxes, and SPAM. Of these, only Death seems affordable!
SVCDummy -
Thanks for the replies again
I have tried using DVIO and hey guess what-it doesnt workEverytime I try to capture I get an error message saying "DVIO has caused an error in KERNAL32.dll DVIO will now close"
I will try ScenalyzerLive when I get a chance-but I dont hold out much hope.
KD -
Did you install a TWAIN driver? I know that's old.....bit I suspect your missing a device driver somewhere. You said it dodn't come with much. Try a generic camera, or maybe a similiar model?
Gazorgan
Now I really am confusedI have never heard of a TWAIN driver before. I did a quick search and came up with this
http://www.canondv.com/downloads/camcorder_software.html
My camera isnt listed but a ZR70MC is, according to SVCDummy my camera is the UK equivalant of the ZR series. Do you think I should try this download or am I on the wrong track totally.
Cheers
KD -
Could you please post link to your camcorder details on manufacturer website in UK ? I am lazy to do that.... Question that I have is ... Is it MiniDV or MIcroDV ? Does it have DV OUT enabled ?
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
KD2 Yes! Equivalent or 'almost the same' usually work. It's the same with printers, you can often select an older printer driver to use with a newer printer to make the software think it's using something it knows. The same applies to DV Cams.
Most of the settings are dealing with how to control the camera from the computer, so the software can capture.To Be, Or, Not To Be, That, Is The Gazorgan Plan
URGENT! Firewire card for computer
By dakota413 in forum Capturing and VCRReplies: 9Last Post: 10th Aug 2011, 17:22 -
does capture of firewire use the sound card?
By Cazz in forum Capturing and VCRReplies: 4Last Post: 24th Jan 2010, 16:45 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 11:19 -
DV Camera to DVD plus Firewire Card Help.
By Sikander in forum Capturing and VCRReplies: 6Last Post: 12th Oct 2007, 14:35 -
What Firewire Card for a Camcorder?
By rakun in forum ComputerReplies: 5Last Post: 12th May 2007, 09:20
