I'm trying to author a DVD using IfoEdit, the problem is that the final result plays video faster than should be, audio goes at normal speed, but video goes faster.
any idea
thanks
You did not give much info but ...
The frame rate of your video is incorrect.
It may have been 23.9 with pulldown and now it is set to 29 or 30.
I have seen this problem myself. All the utils I tried said 29 fps but is really 23.9 with pulldown. Commonly a DVD film source.
Are you using PAL or NTSC?
what steps did you go thru up to this point, source, software and settings? -
Weird...I'm having the exact same problem.
I search another site's forum and found a posting with the same problem...and it had no replies.
I searched this forum and found about 4 threads with the EXACT same problem and NONE of those had any replies!
I sent a private message to one of the posters and he said he corrected the problem by converting his wav file to mp2.
I haven't tried that yet...but he claims it worked. -
...nope
I converted the wav file to a mpeg2 in Tmpgenc and my dvd is still crap.
wow this is my prob too i got an avi source convert it to dvd compliant mpeg in tmpg using the standard ntsc template (the output plays fine in powerdvd) then i use ifoedit to author and if i burn it to dvd+r it appears to miss freeze frames) if i simply play the vob same result if i create an iso mount it in deamon then play it in powerdvd same result
i stress the dvd mpeg plays fine its only after i demux and author the probs start
I need IFOedit for Mac
By bryceguy in forum MacReplies: 7Last Post: 14th Dec 2011, 11:45 -
Changing a 4:3 menu to 16:9 using ifoedit
By NBninja8 in forum Authoring (DVD)Replies: 4Last Post: 20th Jan 2009, 20:11 -
ifoedit question
By J. Baker in forum Newbie / General discussionsReplies: 3Last Post: 17th Sep 2007, 03:10 -
IFOedit question...
By Djard in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2007, 00:42 -
adding CC with ifoedit
By loster in forum Authoring (DVD)Replies: 0Last Post: 9th May 2007, 19:15
