i just ripped a dvd and everyone is bluse what could have happen is there a way to get by this. or is the dvd companys catching up?
if anyone can help with the coloring process back to normal please reply
When I have my s-video cable unplugged from my capture card the capture screen is all blue (like a VCR with no tape inside). Perhaps you have a cable installed wrong. You should double check your conections.
JMO -
was the movie, the smurfs
You know that somebody had to do that.
Seriously, though. There is no way to help based on the information you gave. What movie specs, what software are you using to rip it. It is on the monitor blue and the Cd is fine or vice versa.... -
I had this problem couple of week ago. PowerDVD was corupted (or the DVD player it install anyway)
Try reinstalling DVD software player. -
well I ahve been ripping directly from my dvd player the movie is hot chick. i have a lot of movies and this 1 plus barbershop comes out with the people being blue. I am not capturing or anything just plan ol ripping from dvd using dvd shrink. all the other movies have been perfect.. should I use another software besides dvd shrink?
What would happen to a subtitle of a movie in mkv format if I split it?
By SunKissUAE in forum SubtitleReplies: 1Last Post: 15th Jan 2012, 08:41 -
Use DVD subtitle on a Blue-Ray movie
By AL66 in forum Newbie / General discussionsReplies: 2Last Post: 26th Jun 2010, 17:42 -
DownLoading Blue-Ray Movie
By Iambob in forum Authoring (Blu-ray)Replies: 4Last Post: 19th Feb 2010, 22:45 -
Creating Menu Based Blue Ray with HD & SD footage
By RaV4MaN in forum Authoring (Blu-ray)Replies: 7Last Post: 5th Jun 2009, 21:46 -
d2mp 3.8 & Video Problem - Blue Shade
By gonwk in forum Video ConversionReplies: 13Last Post: 14th Aug 2007, 19:23
