I've heard that black Memorex CD-Rs are good but I'm not sure if they're overburnable to 99 mins. Does anyone know any 80 min. CDs that are capable of overburning up to 99 min? Do they actually exist?
I have a CD writer that could burn up to 99 min, so no need to warn me about hardware issues. :P
None. Some 80 min CDR's can overburn to 81:00, maybe 81:30 . To burn to 99 minutes you need 99 minute CDR's. It will say right on the package 74, 80, 90, or 99 minutes ( the little business card ones don't count ). This assumes your CDRW drive can write to them (the write-head needs to go places it normally doesn't.....ummmmm....that sounds bad :P ).
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
You need to get some 90min or 99min cd-rs. I get mine from eBay or www.precisioncddvd.com. Make sure your drive is compatible and you have the correct software to overburn.
The only problem is that I don't buy stuff online, nor are there any 90-99 min. CD-Rs available in Hong Kong.
This sux.
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 09:41 -
What are good specs for a high-quality MP4 file? (Will look good on my 40&q
By HarlanPepper in forum Video ConversionReplies: 6Last Post: 11th Feb 2009, 03:18 -
Good name
By Delta2 in forum Off topicReplies: 2Last Post: 4th Jun 2008, 23:07 -
why is there 16:10? Is 16:9 not good enough??
By turk690 in forum Newbie / General discussionsReplies: 5Last Post: 6th Feb 2008, 19:07 -
Looking for some good instrumental music that would be good for football.
By ingeborgdot in forum AudioReplies: 8Last Post: 26th Nov 2007, 21:18
