I have heard that using lables on dvd-r's can cause them not to play on dvd players because of a weight issueis this true ? as i like the look of a labels dvd (seems more profesonal and finalized)
Andy
If a computer Bites you BYTE it back -
There are alot of posts on this issue here. I myself thought they were silly, what do you mean your movies skip? I don't have any problems. UNTIL the dreaded day I did have one skip on me, I ruined the disc trying to remove the label so I remade the video and did everything the same and it played fine. I agree they look alot better but if you are looking for "Professional" results, playing without a glitch in more professional than how the disc looks in it's case. I won't use them anymore. Just my 2 cents. Do a search for "sticky labels" and I know you will find all the other posts on this. Good luck
DVD labels
By Ogilvy in forum MediaReplies: 18Last Post: 19th Dec 2009, 22:37 -
Removing Hub Labels
By rvman in forum MediaReplies: 10Last Post: 3rd Jul 2008, 12:06 -
To print labels
By mis3 in forum MediaReplies: 9Last Post: 23rd Dec 2007, 09:27 -
CD / DVD Labels - Which ones should I get?
By jcm0320 in forum MediaReplies: 4Last Post: 15th Dec 2007, 22:01 -
CD / DVD Labels
By wesmoc in forum Newbie / General discussionsReplies: 6Last Post: 7th Jul 2007, 08:42
