Folks,
I am looking for a contact in Ricoh.
At least one drive I am aware of 5125A cannot read media info on a blank DVD+R/RW because the READ_DVD_STRUCT 01h command fails.
This means the disc must be used before the user can get media code on a disc which is inconvenient.
This fault does not occur with the Sony 500ax which can read DVD+R/RW media code fine on unwritten discs.
I would like to mail someone at Ricoh and see if we can get this fixed for find a work around for reading the data from Physical Format Information if possible.
cheers
nicw
Author DVDInfo
nicw
It's the same thing with the NEC drives too AFAIK (at least I can't use the "Physical format command" on a blank DVD+R/RW with my ND-1100A).
VOB2MPG - How to use /DVDInfo parameter
By mmoore99 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 2nd Mar 2012, 02:05 -
Contact of Gmail
By Jomapil in forum ComputerReplies: 4Last Post: 11th Aug 2011, 12:47 -
UN selecting Ambassador for Alien Contact
By deadrats in forum Off topicReplies: 2Last Post: 28th Sep 2010, 12:48 -
XviD4PSP contact
By leghorn in forum Video ConversionReplies: 7Last Post: 31st Dec 2009, 11:19 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 19:30
