I had some failure of some kind and I can't seem to fix it. I'm using a Canopus ADVC-50 caputure device and that feeds a firewire card. I mostly capture with Scenealyzer, but the failure is universal for all capture programs.
I'm running a P4 1.6GHz w/ 256MB RAM and I burn using Pioneer DVR-A05.
Two things on my computer changed in between the time that capturing worked and failed. First, I installed NMapWin (port scanning software) to do some security work on my mail server. Second, I ran Norton WinDoctor from the CD. I have since uninstalled NMapWin, but the changes made by Norton can't be undone.
Various capture programs react differently. DVD Workshop says that the file is corrupt and asks if I want to delete it. Vegas Video says that its actively capturing, but when you stop, it says that it has captured 0 frames. Scenealyzer captures, but the image looks like the one below, and it only captures 2 or 3 frames before writing to a new file.
I have replaced both the ADVC-50 and the firewire card.
Anyone recognize this type of image?
Thanks in advance.
Sorry, the image didn't upload correctly. Go to:
http://www.lonnhunter.com/scene0002.jpg
Image is about 135KB
Thanks again. -
Yes, I reinstalled two of the three capture applications I use, I didn't reinstall Scenealyzer because it doesn't get installed in the first place; it just runs without being installed.
Just a follow up.
I formatted my c drive and re-installed everything. Now things are working correctly. My conclusion is that Norton Systemworks screwed something up that I could never identify. If anyone has this program, make sure you enable the undo when you run Win Doctor.
Cant get either video capture card to work
By ralphey in forum Capturing and VCRReplies: 1Last Post: 6th Aug 2011, 21:02 -
I may have too many video programs- I cannot get my capture to work
By FLVidiot in forum Newbie / General discussionsReplies: 0Last Post: 6th Aug 2010, 00:45 -
Looking for a new vhs capture work flow
By yoda313 in forum Capturing and VCRReplies: 6Last Post: 27th Sep 2009, 21:10 -
Capture Cards that work with Media Encoder 9.0
By alec_owen in forum Capturing and VCRReplies: 1Last Post: 8th Jan 2008, 08:26 -
WANTED: Ongoing capture work
By tvtodd in forum Capturing and VCRReplies: 2Last Post: 29th Nov 2007, 22:51
