Just wrote my first disc using the walkthough here called "DVD9 to DVD5 with DVD2ONE " it wrote fine and plays great on my JVC dvd player, but when I try to play it on my computer through my SONY DRU-500ax, it has no sound. The Power DVD 'show info' screen says no audio info available.
any ideas?![]()
Thanks,
Troy
Results 1 to 11 of 11
what did you burn the dvd with which software
my mistake i thought you had burned the disk because i had this problem and it was to do with the software i was using -
Did you check the audio stream you wanted to keep when you setup DVD2one (like DTS, Dolby 5.1, etc)?
I used this walkthrough just like it says.
https://www.videohelp.com/forum/userguides/141024.php#dvd9dvd2one
Yes, I did play back a commercial DVD and the sound played just fine. So I don't think it's the wiring or hardware. (CD audio plays fine too)
I do remember checking which audio I wanted too. The audio on the player is in DTS..maybe that's why it won't play on the sony??? I'm not sure it plays in DTS or not. -
Just a thought - there is an internal cable connecting the cd/dvd drive to the soundcard inside the computer. If you installed the dvd-rw drive after the original drive, and didn't move the internal audio cable then I think that may explain why you get no sound.
If you have another drive (and its a DVD-ROM) try the disk in that. If the other drive is a CD drive, and you want to play DVDs on your PC, you may have to move the internal audio cable from your original drive to your Sony.
Don't have a DVD-RW drive myself so I'm just guessing ! -
Nope...just one drive and like I said it plays all other media fine. Comm DVD and CD Audio)
Thanks anyway! -
DVD2ONE does not correct the ifo file in full mode. Unless you included stream 00 in the compression you will hear no audio,use the button on the remote to cycle thru your audio streams.
I contacted the author about this "problem" but he says he knows and it's intentional. -
So this would cause it to play on a regular home DVD player and not the ROM drive?
Did you choose only DTS for sound without AC3? I believe DVD format require you include at least one AC3. Also maybe your power dvd player doesn't have DTS package. The power dvd included in DVD-Rom drive generally doesn't have DTS package. When you start power dvd did you see the DTS logo? if not your power dvd player doesn't have DTS package.
no audio when played in DVD player? help
By cpeters12 in forum Authoring (DVD)Replies: 2Last Post: 29th Jul 2009, 17:01 -
Overscan on DVD played back on a computer
By maeks84 in forum Authoring (DVD)Replies: 6Last Post: 21st Feb 2008, 09:02 -
No audio when DVD Folder is played on Netgear Digital Entertainer.
By Back2Future in forum Authoring (DVD)Replies: 6Last Post: 23rd Nov 2007, 02:42 -
no audio when played on dvd player
By soccer in forum AudioReplies: 6Last Post: 4th Aug 2007, 19:18 -
Aspect Ratio When Played on a Computer Directly Plugged into a TV
By dcabiness in forum Video ConversionReplies: 3Last Post: 22nd Jul 2007, 20:16
