i am looking to import 100 pictures into premiere 6.5 and have them "maintain aspect ratio" and hopefully each one have a diffrent random transition. i would also like to be able to select a time length for each picture on the time line (ex: 5 seconds, 7 seconds, whatever)
i know all of this can be done on a picture per picture basis, but i am looking for a one click easy solution
anyway, if this is all to much to ask for i understand, but maybe, just maybe i could get 1 or 2 of these knocked out.)
any takers?
thanks.
I'm not sure if this answers your question but you can set a default duration for all imported still images.
Select "edit" -> "preferences" -> "General and Still Image". You will see a deault duration defined as the number of frames. This is where you set a duration. For example, if you wanted a 5 second duration, set the value to frames value * 5 (frames value = your project's frames per second, i.e 30 fps).
To import the pictures just select all of them and bring them into the bin.
Good luck. -
hey thanks, i also can check off maintain aspect raito there as well.
preciate the help. -
I actually just did this, but I do not think there is a way to add random transitions.
I wish there was, it would make my life much easier!
-Machine
Need to export movie in Premiere Pro 1.5. What settings?
By vid83 in forum EditingReplies: 5Last Post: 23rd Mar 2013, 17:13 -
Settings for Premiere smart render/how to tell if it's working...
By rcavanah in forum EditingReplies: 8Last Post: 14th Sep 2011, 18:20 -
default settings to export quicktime in premiere
By kidkunjer in forum EditingReplies: 0Last Post: 16th Sep 2010, 02:03 -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 04:22 -
Best export settings in Adobe Premiere CS4
By Polesch in forum Newbie / General discussionsReplies: 5Last Post: 5th Apr 2010, 17:45
