When I try to burn in DVDit I get the error "GOP header must be preceded by a sequence header". How do I do this? I use TMPGEnc to convert to mpeg.
It depends on your version of TMGPEnc, but there is an option within the program to specify "Output interval of header = 1". You need to make sure this is enabled, so that a header will be placed before every Group Of Pictures (GOP), then re-encode your MPEG with this setting, and everything should work perfectly.
To make life easier for you, just read the guide by Rui del-***** / Azul SPI:
http://dvd-hq.info/Compression.html
Arky ;o)
Which GOP program?
By pboong in forum Video ConversionReplies: 2Last Post: 16th Sep 2010, 13:19 -
Questions about GOP.
By Sean_ve99 in forum Newbie / General discussionsReplies: 11Last Post: 9th Jun 2007, 00:08 -
VCD to DVD (TDA error: GOP too long)
By jelir in forum Authoring (DVD)Replies: 1Last Post: 6th Jun 2007, 10:40 -
SCR <> GOP error in Gui for DVD Author
By rain in forum Authoring (DVD)Replies: 6Last Post: 22nd May 2007, 12:51 -
Glossery - Error in Closed GOP definition
By SCDVD in forum FeedbackReplies: 0Last Post: 8th May 2007, 19:08
