Hi,
Yes I am experiencing a problem that I was hoping someone might be able to help me with. I am trying to burn 3 seperate episodes both around 250 mb onto a vcd already into mpg. The problem is that when i burn it the last 5 minutes skip and freeze and are basically messed up. I was wondering what I could do to fix this any help would be appreciated I am not sure whether it is too big or something wrong with the prog I am using some sort of setting (i am using nero). I believe that a vcd holds 800 mb but i may be mistaken. Thank you e-mail back if you can help thank you very much.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 1 of 1
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
